Hello
Guest
it is
November 28, 2026, 06:37:21 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Memory leak win2000 mach3 v3.041
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Memory leak win2000 mach3 v3.041 (Read 50745 times)
sven_d
22
Re: Memory leak win2000 mach3 v3.041
Reply #20 on:
July 07, 2009, 02:42:26 AM »
Just checked and there is no pulse engine, I dont think its needed with g100.
I installed it anyway to see if it did anything but the memory leak is still the same.
Sven
Logged
Carnoustie, Scotland
Reply #21 on:
July 07, 2009, 03:30:00 AM »
Ah ok, sorry forgot the G100 was being used, think I remember you tried earlier with re-setting device and using it as the parallel port and you still had problems.
Dont know what else to suggest.
Logged
sven_d
22
Reply #22 on:
July 07, 2009, 03:41:03 AM »
thanks for your help Hood
Sven
Logged
sven_d
22
Reply #23 on:
July 07, 2009, 03:43:59 AM »
I have lodged a Bug Report #0018, hopefully they will try and investigate further or offer a clue as to what is going on here.
Sven
Logged
Reply #24 on:
July 07, 2009, 03:56:42 AM »
I know, I responded to it
Have had a few others test and no one else has the problem so far
Have also had the laptop running away since Saturday and it has been steady at 178K
Logged
sven_d
22
Reply #25 on:
July 07, 2009, 04:22:52 AM »
do you think its worth uninstalling mach3 and reinstalling? I dont really want to do anything major with windows as the pc is far from network.
Sven
Logged
Reply #26 on:
July 07, 2009, 04:27:53 AM »
Everything is worth a try, what I would do is rename the Mach3 directory then install Mach, that way all your previous setup will still be there just not getting used.
Logged
sven_d
22
Reply #27 on:
July 08, 2009, 02:50:58 AM »
Did another install of mach3, still the same,
Hood, do you think if I format the hard drive and reinstall win2000 the problem will be cured.
Sven
Logged
Reply #28 on:
July 09, 2009, 12:58:48 AM »
Formatting the drive may help, I think however I would try disabling the services one at a time to see if you can find the problem. Also try the optimisation steps detailed on the downloads page.
Logged
sven_d
22
Reply #29 on:
July 09, 2009, 02:15:23 AM »
Just finished formatting and all is good, no more memory leaks and its going like a rocket, I'm leaving win2000 with no updates to see what happens.
Thanks for your time Hood.
Sven
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
