Hello Guest it is November 13, 2026, 04:59:11 PM
Author Topic: How I made my pendant.  (Read 153600 times)
Offline Bengt
  •  54 54
    • Private CNC site
Re: How I made my pendant.
« Reply #70 on: April 26, 2010, 11:39:19 AM »
Dear Boris,
I asked a polight question on how and why it is like that, your answer is no answer.
Even if it is a bit 'technical' I would like to see more detailed answer why it is like that and why the 2nd configuration.
Bengt
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #71 on: April 26, 2010, 03:00:54 PM »
OK, it wil not help you, but you wanted....
PoKeys55 has limited number of pins. Try to configure all possible peripherals, and you will see the reason.
There are not enough free pins!  It could be done in way If 2 LCDs will work, then peripheral X will not work.
But that will add unnecesary complexion and possible unreliability.
Also every microcontroller has limited number of peripherals.
Satisfied?
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline Bengt
  •  54 54
    • Private CNC site
« Reply #72 on: April 26, 2010, 03:35:58 PM »
Ok Ok I hear you Boris
Bengt
