Hello Guest it is November 01, 2026, 01:04:38 PM
Author Topic: bit coming down as its still moving forward to cut??  (Read 25575 times)
« on: June 15, 2009, 12:42:52 PM »
lazycam seems to be putting a ramp in every program we do.2 complete computers we have had the same problem.the bit is coming down still as it is moving forward to cut.it doesnt do it in the programs already produced in mach3.thinking its lazy cam software....getting very frustrated trying to use this for 2 months now...thank you to all ahead of time!! tom gillett in upstate ny
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: bit coming down as its still moving forward to cut??
« Reply #1 on: June 15, 2009, 03:52:50 PM »
Hi, Gilletttom
Post one of the dxf & G code file's your having problem's with, Use the REPLY button and Attach them.
Chip
« Reply #2 on: June 15, 2009, 07:09:20 PM »
it is doing it to every single file we produce with lazycam .attached is a dxf  file and g code file thank you very much
Offline Chip
  •  2,055 2,055
« Reply #3 on: June 16, 2009, 12:41:40 AM »
Hi, Gilletttom
Your dxf file is zero in size, Re-post it you'll need to re-name it though to post it.
I do see what your talking about, There are a bunch of x axis and Z axis move's on the same line's in the G code file you posted.
Look in Mach3 & LazyCam Under "Help", What version's are you using.?
Back plotted your G code file in/with nc-plot and generated code with similar values you used, See first attached file.
Used LazyCam ver 3.00.2 and it seems to function OK.
We can get in to better way's to setup LC after were on the same page and at least get you going in the right direction..
Chip
« Last Edit: June 16, 2009, 12:49:06 AM by Chip »
Offline Chip
  •  2,055 2,055
« Reply #4 on: June 16, 2009, 01:54:26 AM »
Hi, Gilletttom
Hera's a pic and a G code file that might be more typical of settings usage in LazyCam.
Chip
« Reply #5 on: June 16, 2009, 07:55:51 PM »
i am using the 300.2 version.i tried your file and it worked great.and i used your setup as in photo and lazy cam is still producing same code.we have ran the re-install program tonight and it made no difference which we new it wouldnt since this is going on ,on 2 seperate computers. thank you much ,tom
Offline Chip
  •  2,055 2,055
« Reply #6 on: June 16, 2009, 08:47:36 PM »
Hi, Gilletttom
Are you using the "Default" Post as in the picture below, That's what I posted the code with.
Chip
« Reply #7 on: June 17, 2009, 11:44:44 AM »
i am using the default, all settings are the same as yours..purchased software about 1 year ago..was good for 6 months when the power supply went on the computer at which time i used a different computer actually 2 computers in a 2 week period both running XP and this is where the problems began . the software has not ran right since and now i have my original computer back which runs VISTA and again it is not running right.i believe it may be the download itself is there a way for us to get it other than the net maybe its a corrupted file. thank you tom
Offline Chip
  •  2,055 2,055
« Reply #8 on: June 17, 2009, 01:12:51 PM »
Hi, Gilletttom
Try deleting your LazyCam.xml file then run LazyCam and give it a another try, The xml should be in C:\Mach3 folder if you have a standard install.
Post another dxf file hear, As your other one was bad that you posted.
Chip
« Reply #9 on: June 17, 2009, 08:58:05 PM »
i deleted the xml file and it seems to work though i didnt have alot of time to work wit it...will test it further tommorow night..here is the file i sent this already but said error so if you get a couple sorry!! ;D..thank you for your help talk tommorow night..thx tom :)
