Hello Guest it is November 24, 2026, 01:09:42 PM
Author Topic: Gerber Dimension 200 Router  (Read 14867 times)
« on: June 09, 2009, 03:42:17 PM »
Recently purchased a used Gerber Dimension 200 router, without any software. The Mach 3 output is parallel, the Gerber needs serial input to the ARC controller. Saw a post from last year with no solution. Any help out there?
Signman in St. Cloud , fl.
Re: Gerber Dimension 200 Router
« Reply #1 on: June 09, 2009, 03:52:13 PM »
Afraid your only option will be to find out how things are conected and then if possible rewire for the parallel port.
« Reply #2 on: June 11, 2009, 08:32:37 AM »
Signman, the Gerber system is proprietary so can't be easily converted.
The ARC station is a micro controller and servo driver all in one, it communicates with the Gerber software and does not accept step/direction type inputs.
Zax.
