Hello
Guest
it is
November 22, 2026, 07:36:54 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Send pulses in breakout board
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Send pulses in breakout board (Read 15182 times)
ostie01
628
on:
May 21, 2009, 04:09:11 PM »
Is it possible to send 5v pulses to the input of a C10 breakout board to jog.
Would like to send a clocked frequency to the input and jog..
Thanks for your help.
Jeff
Carnoustie, Scotland
Re: Send pulses in breakout board
Reply #1 on:
May 22, 2009, 05:07:41 AM »
Not really sure exactly what you are meaning but if its what I think then you should be able to send pulses if they are similar to a MPG, ie A and B channels, then just tell Mach it is a MPG.
ostie01
628
Reply #2 on:
May 23, 2009, 02:02:30 PM »
Hi, what i would like to do is send 5v pulse to the pin of my BOB.
I know how to do all the electronics but not sure if Mach3 can handle this.
The pulses could be at variable frequency to jog faster or slower like changing the feed.
Reply #3 on:
May 23, 2009, 02:19:58 PM »
Jeff,
Are you meaning to do something like the XBOX360 which allows pressing of a button to go from a slow velocity
to max velocity when jogging?
Reply #4 on:
May 23, 2009, 02:57:19 PM »
If you could send two pulses 90 degrees out to two pins then you could set it up as a MPG, just sending one pulse to one pin I dont think would work.
ostie01
628
Reply #5 on:
May 23, 2009, 03:41:50 PM »
So, Just I would have to do is send pulses to one pin and for the other pin,the signal should be 90 degres out of phase.
I could give it a try.
Thanks, Jeff
Reply #6 on:
May 23, 2009, 03:44:47 PM »
Yes that should work as that is all a MPG is.
Print
Pages:
1
Go Up
« previous
next »
