Hello Guest it is November 26, 2026, 06:47:14 PM
Author Topic: Send pulses in breakout board  (Read 15206 times)
« on: May 21, 2009, 04:09:11 PM »
Is it possible to send 5v pulses to the input of a C10 breakout board to jog.
Would like to send a clocked frequency to the input and jog..
Thanks for your help.
Jeff
Re: Send pulses in breakout board
« Reply #1 on: May 22, 2009, 05:07:41 AM »
Not really sure exactly what you are meaning but if its what I think then you should be able to send pulses if they are similar to a MPG, ie A and B channels, then just tell Mach it is a MPG.
« Reply #2 on: May 23, 2009, 02:02:30 PM »
Hi, what i would like to do is send 5v pulse to the pin of my BOB.
I know how to do all the electronics but not sure if Mach3 can handle this.
The pulses could be at variable frequency to jog faster or slower like changing the feed.
« Reply #3 on: May 23, 2009, 02:19:58 PM »
Jeff,
Are you meaning to do something like the XBOX360 which allows pressing of a button to go from a slow velocity
to max  velocity when jogging?
« Reply #4 on: May 23, 2009, 02:57:19 PM »
If you could send two pulses 90 degrees out  to two pins then you could set it up as a MPG, just sending one pulse to one pin I dont think would work.
« Reply #5 on: May 23, 2009, 03:41:50 PM »
So, Just I would have to do is send pulses to one pin and for the other pin,the signal should be 90 degres out of phase.
I could give it a try.
Thanks, Jeff
« Reply #6 on: May 23, 2009, 03:44:47 PM »
Yes that should work as that is all a MPG is.
