Hello
Guest
it is
October 21, 2026, 08:16:32 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
MPG - BUTTON
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MPG - BUTTON (Read 15989 times)
jdmaya
60
MPG - BUTTON
on:
May 16, 2009, 12:28:56 PM »
as I do to run a macro with the touch of a button from an MPG?
thanks.
Carnoustie, Scotland
Re: MPG - BUTTON
Reply #1 on:
May 16, 2009, 01:21:46 PM »
Sorry dont understand what you are asking, can you try and explain a bit more please.
jdmaya
60
Re: MPG - BUTTON
Reply #2 on:
May 18, 2009, 07:22:35 AM »
I want to record ccordenadas X, Y, Z to a file by clicking on a button of my MPG.
Thank you.
Overloaded
4,923
Re: MPG - BUTTON
Reply #3 on:
May 18, 2009, 07:31:12 AM »
I'm guessing.....a button on the pendant ?
jdmaya
60
Re: MPG - BUTTON
Reply #4 on:
May 19, 2009, 04:52:47 PM »
yes, a button on the mpg that enable a button on the screen which functions to record the coordinates X, Y, Z.
Re: MPG - BUTTON
Reply #5 on:
May 19, 2009, 05:29:16 PM »
What make of pendant do you have?
If you can set the button to be an OEM Trigger then the easiest way would be to get the MachMad plugin and use that to call a macro when it sees the button push. You could then write a macro to do what you want.
jdmaya
60
Re: MPG - BUTTON
Reply #6 on:
May 20, 2009, 08:27:47 AM »
I am working with a dspmc.
Syl
5
Re: MPG - BUTTON
Reply #7 on:
October 14, 2009, 11:57:33 PM »
this is a test.
Print
Pages:
1
Go Up
« previous
next »
