Hello Guest it is November 22, 2026, 02:08:21 PM
Author Topic: MPG - BUTTON  (Read 16338 times)
MPG - BUTTON
« on: May 16, 2009, 12:28:56 PM »
as I do to run a macro with the touch of a button from an MPG?
thanks.
Re: MPG - BUTTON
« Reply #1 on: May 16, 2009, 01:21:46 PM »
Sorry dont understand what you are asking, can you try and explain a bit more please.
Re: MPG - BUTTON
« Reply #2 on: May 18, 2009, 07:22:35 AM »
I want to record ccordenadas X, Y, Z to a file by clicking on a button of my MPG.
Thank you.
Re: MPG - BUTTON
« Reply #3 on: May 18, 2009, 07:31:12 AM »
I'm guessing.....a button on the pendant ?
Re: MPG - BUTTON
« Reply #4 on: May 19, 2009, 04:52:47 PM »
yes, a button on the mpg that enable a button on the screen which functions to record the coordinates X, Y, Z.
Re: MPG - BUTTON
« Reply #5 on: May 19, 2009, 05:29:16 PM »
What make of pendant do you have?
 If you can set the button to be an OEM Trigger then the easiest way would be to get the MachMad plugin and use that to call a macro when it sees the button push. You could then write a macro to do what you want.
Re: MPG - BUTTON
« Reply #6 on: May 20, 2009, 08:27:47 AM »
I am working with a dspmc.
Offline Syl
  •  5 5
Re: MPG - BUTTON
« Reply #7 on: October 14, 2009, 11:57:33 PM »
this is a test.
