Hello Guest it is October 12, 2026, 12:09:10 PM
Author Topic: Problem configuring ncpod  (Read 31920 times)
« on: May 14, 2009, 12:33:13 PM »
Hello all,
I have a problem to setup mach3 for ncpod.
The communication between Mach3 and ncpod is OK, but I don't manage to setup the soft to make move motors.
The following picture is my actual setup of mach 3, please tell me what is wrong.
Freddy
Re: Problem configuring ncpod
« Reply #1 on: May 14, 2009, 12:40:11 PM »
You have not set any pin numbers for step and direction.
« Reply #2 on: May 14, 2009, 12:44:56 PM »
HI,
thanks for your answer.
I tried to do so, but I don't know the value to put as ncpod use a usb plug insteed of a DB25.
Do you know what value to put in ?
Regards
Freddy
« Reply #3 on: May 14, 2009, 02:10:22 PM »
You need a "Plug in" for Mach3 to use the USB port.
Try this one.
« Reply #4 on: May 14, 2009, 02:24:48 PM »
I already install this.
My ncpod and mach3 communique well, but motors don't turn.
I think I did'nt setup then properly in mach3, that's the problem.
So, I don't know if it's necessary to put pin number for step and dir ?
If I have to do that, do you know what pin number I have to put for step and dir setting up for motors?
Freddy
« Reply #5 on: May 14, 2009, 02:34:32 PM »
Sorry, I have no experience with NCPOD.
« Reply #6 on: May 14, 2009, 02:53:46 PM »
« Reply #7 on: May 14, 2009, 02:59:40 PM »
« Reply #8 on: May 14, 2009, 03:45:35 PM »
Unfortunatly,  I didn't find the answer to my problem yet.
However, I thank you again to contributing to that.
Freddy
« Reply #9 on: May 14, 2009, 04:17:21 PM »
I would un install Mach3 and any NC POD drivers. Re install Mach3 without the parallel port driver. then install the NC POD drivers.
