Hello Guest it is September 29, 2026, 02:37:48 PM
Author Topic: Problem configuring ncpod  (Read 31798 times)
Offline Greolt
  •  956 956
Re: Problem configuring ncpod
« Reply #10 on: May 14, 2009, 04:29:48 PM »
If you do not already have this diagram then it may be of some assistance.
Greg
« Reply #11 on: May 15, 2009, 01:57:59 PM »
Thanks Greolt
I have this diagram.
I tried parameters of a guy on youtube that have same gear than me, but that's not the problem in fact.
If I mesure tension with a plaine multimeter, tension for pulse is always 5V when I puch jog button to make move an axis and when I don't! I mesure this tension directly on ncpod. I don't undestand why.
I guess that when I don't "ask" mach 3 to send pulse, tension have to be 0 V! Is that true?
Freddy
« Reply #12 on: May 15, 2009, 02:57:54 PM »
Change the active state and it may go low when not being used.
« Reply #13 on: May 15, 2009, 04:23:27 PM »
Hi Hood,
I already try that, I check again, but unfortunately, it dont change votage when I choose Active Low or not.
I don't understand why I notice this kind of problem on motor output on ncpod.
Freddy
« Reply #14 on: May 15, 2009, 04:33:18 PM »
I am afraid I have never even seen one let alone had one so cant be of any assistance :(
Have you tried emailing the manufacturer?
« Reply #15 on: May 16, 2009, 01:08:33 AM »
Freddy,
I think you would get more help on the two links I gave you that deal with NC POD.
« Reply #16 on: May 16, 2009, 02:23:03 AM »
HI all,
Yes I send some emails to the manufacturer. For my first problem (manage to have a good communication between ncpod and mach3, its help and yours was both necessary. I used a driver for ncpod basic panel which is not suitable for mach3.
Machine master, I will read again the links you advise me to try. Perhaps I haven't see something in.
Freddy
« Reply #17 on: May 30, 2009, 12:23:02 PM »
Hello all,
my 3 motors can run under mach3 now !
I had two principal problems :
- I used an usb drivers not good with mach3 (Carl from Oemtech help me a lot about that)
- my drivers don't have to be connect as a Gecko driver, so ncpod manuel wasn't enough precise for the connection type I needed, but Carl gave me information I needed.
I took a long time to identify and resolve problems, but that's done now !
The machine will run soon, even if its not completely finished.
Regards
Freddy
« Reply #18 on: May 30, 2009, 12:31:03 PM »
Great news :)
