Hello Guest it is November 13, 2026, 08:08:25 PM
Author Topic: Mach3 Lathe Wizards  (Read 14513 times)
Mach3 Lathe Wizards
« on: May 11, 2009, 04:57:58 PM »
Just completed my CNC conversion for the Grizzly G0602 lathe and now am starting the learning and fun phase.  I plan to run in the Diameter mode.  My question is:  Do the "Lathe Turning Wizards" by Brian/Kiran output g-code in diameter or radius mode?
Re: Mach3 Lathe Wizards
« Reply #1 on: May 11, 2009, 05:13:12 PM »
I run Dia mode and the wizards work fine :0
« Reply #2 on: May 12, 2009, 05:35:13 PM »
Tried a wizard out today and alll worked fine in diameter mode.
« Reply #3 on: May 12, 2009, 05:38:34 PM »
I think the VB in the wizards will actually look to see which mode you are in and output accordingly :)
