Hello Guest it is October 05, 2026, 12:23:04 AM
Author Topic: hole macro help please :)  (Read 90639 times)
Re: hole macro help please :)
« Reply #40 on: May 14, 2009, 04:43:18 PM »
oops
damn
wait read wrong again
lemme test a shorter section of code
« Reply #41 on: May 14, 2009, 04:47:09 PM »
nope no go.. still invisible code
30 lines of code
« Reply #42 on: May 14, 2009, 04:51:42 PM »
Afraid the revision I have is the Alpha of the next rev of Mach, it will be at least a few weeks before its on the site.
« Reply #43 on: May 14, 2009, 04:56:31 PM »
.... ok then.. one more project on the back burner..
« Reply #44 on: May 14, 2009, 05:01:32 PM »
I am just restoring the backup folder I have so will see if it behaves the same for me with an older version of Mach as it does for you.
vmax549
« Reply #45 on: May 14, 2009, 05:06:48 PM »
Yall were close BUT there is problems with the VB and M98 on the later versions
Try from a button
Loadfile("c:/path of file/Filename")
Runfile()
Just remember to remove the M99 from the program file and add the M30 to the end of file. Or it may loop continuously in mach(;-)
Works here everytime, (:-) TP
« Last Edit: May 14, 2009, 05:13:36 PM by vmax549 »
« Reply #46 on: May 14, 2009, 05:14:29 PM »
Cool
gonna give that  bash.. unpacking shop now :)
« Reply #47 on: May 14, 2009, 05:14:44 PM »
So why did you not come here days ago and save us all this pain ;D
« Reply #48 on: May 14, 2009, 05:20:52 PM »
Just for the record I replaced my screwed up folder with the backup and its doing exactly as it was for you guys so looks like its fine in the future Rev but not in these.
TP's way should work fine, will have to note that down :0
« Reply #49 on: May 14, 2009, 05:43:02 PM »
Just tried it and it didnt work, so put a sleep(1000) in and it started fine.
