Hello Guest it is October 04, 2026, 10:59:08 PM
Author Topic: hole macro help please :)  (Read 90613 times)
Re: hole macro help please :)
« Reply #30 on: May 14, 2009, 04:20:53 PM »
....saw that too Chris. And if you hit EDIT CODE, it's there. Close that window and it loads properly.
I beat on this for a while earlier and gave up.  lol
RC
ummm ok.. think this will be addressed?  kind of make my whole exercise pointless if i can load code from a macro?
« Reply #31 on: May 14, 2009, 04:21:50 PM »
Works perfectly here but I had to change the M99 at the end of your code to a M30. I also added  the regen button in the VB so that the toolpath will display.
« Reply #32 on: May 14, 2009, 04:25:56 PM »
ok.. i leave this alone till its sorted in a next revision perhaps.. im trying to simplify the process and as it stands its easier to explain to end users how to simply load the code manually than to get macro working right. .. less button presses actually lol
thanks for all the help guys :)
« Reply #33 on: May 14, 2009, 04:27:47 PM »
Only one button press needed here, I have the regen done in the macro.
« Reply #34 on: May 14, 2009, 04:32:15 PM »
ahh ok sorry never read properly
lemme test
« Reply #35 on: May 14, 2009, 04:35:29 PM »
Ah well it may be due to the fact I have Rev4 here, have tried to go back but my xmls are screwed so not sure if the reason its not working now is because of that or because its and older revision.
« Reply #36 on: May 14, 2009, 04:36:26 PM »
nope still invisible code...
« Reply #37 on: May 14, 2009, 04:38:55 PM »
What happens if you write a short G code program with the M98 call?
« Reply #38 on: May 14, 2009, 04:40:53 PM »
actually manually clicking regenerate in my screen does not fix it either...
hitting edit button does th etrick but thats not a solution for what I need unfortunately.
how would i upgrade my mach to your revision? is it covered in my license?
« Reply #39 on: May 14, 2009, 04:41:20 PM »
that works fine.. i played with it lots last night..
the
Code ("G0X0Y0Z50A0")
part of code runs great ... its after the m99 that it all goes pear shaped..
