Hello Guest it is October 13, 2026, 12:46:30 PM
Author Topic: New to Lathe  (Read 26554 times)
Re: New to Lathe
« Reply #10 on: May 04, 2009, 02:43:28 PM »
It was one of your countrymen that made that screen ;D
Maybe makes sense to people who use  industrial controls, I dont know, but sure didnt make sense to me, then again I am just a Fisherman :)
Re: New to Lathe
« Reply #11 on: May 04, 2009, 03:03:33 PM »
I tried the Blue one, it's given me a headache  ;D
I have no experience of industrial controls but that's what Mach is
I guess i will have to go on another learning curve.
Phil
Re: New to Lathe
« Reply #12 on: May 04, 2009, 03:07:00 PM »
Or open a mill screen of your choice with screen4 and remove all the Y axis stuff and stuff that relates top Mill only, then save as a .lset ;)
Re: New to Lathe
« Reply #13 on: May 04, 2009, 03:11:35 PM »
I did have that very idea, but i want to use the thing.
Not spend all my time on designing a screen set which is another learning curve.
Then there is the brains learning curve.
Phil
Re: New to Lathe
« Reply #14 on: May 04, 2009, 03:15:06 PM »
No learning curve there, as long as you can left click and press the delete key, then once done choose File, Save As and then make sure your extension is .lset   ;)
Brains are fairly straightforward as well, you will soon get the hang of them, doing modbus stuff in it may be a bit more tricky, never tried that.
