Hello Guest it is October 22, 2026, 05:09:25 PM
Author Topic: Reset Interpreter button in Setting screen  (Read 12641 times)
« on: April 23, 2009, 01:26:00 PM »
What is an Interp(reter)?
It is a button in the Setting screen whitch is labeled "Reset Interp". What is the function of this button?
Re: Reset Interpreter button in Setting screen
« Reply #1 on: April 23, 2009, 01:34:20 PM »
Resets the GCode states to startup defaults.
« Reply #2 on: April 23, 2009, 01:53:58 PM »
Is the "Use init string on ALL reset" supposed to be checked? The init string is G80.
If not checked the G80 in mode line changes to G1 when resetting interpreter, when checked the G1 changes back to G80 when resetting E-stop.
« Reply #3 on: April 23, 2009, 01:57:52 PM »
If you have something in the initialisation string then yes it is likely that you will need that checked.
