Hello
Guest
it is
November 10, 2026, 03:15:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Reset Interpreter button in Setting screen
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Reset Interpreter button in Setting screen (Read 12856 times)
SteinarN
155
on:
April 23, 2009, 01:26:00 PM »
What is an Interp(reter)?
It is a button in the Setting screen whitch is labeled "Reset Interp". What is the function of this button?
Logged
Carnoustie, Scotland
Re: Reset Interpreter button in Setting screen
Reply #1 on:
April 23, 2009, 01:34:20 PM »
Resets the GCode states to startup defaults.
Logged
SteinarN
155
Reply #2 on:
April 23, 2009, 01:53:58 PM »
Is the "Use init string on ALL reset" supposed to be checked? The init string is G80.
If not checked the G80 in mode line changes to G1 when resetting interpreter, when checked the G1 changes back to G80 when resetting E-stop.
Logged
Reply #3 on:
April 23, 2009, 01:57:52 PM »
If you have something in the initialisation string then yes it is likely that you will need that checked.
Logged
Print
Pages:
1
Go Up
« previous
next »
