Hello Guest it is November 13, 2026, 08:05:05 PM
Author Topic: THC300 jumps up down  (Read 12355 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
« on: April 19, 2009, 10:52:08 AM »
I just started cutting a straight line for testing. I see torch goes all the time up and down for small amount and Up and Down leds goes on and of 2 to 3 times per second. The cut is not ideal. Material is 4 mm steel, and 60 amps
What to adjust in this case?
Miroslav
Re: THC300 jumps up down
« Reply #1 on: May 11, 2009, 02:11:04 AM »
mrpeja
I have same Problem...did you figure out how to fix this...
Offline mrpeja
  •  114 114
« Reply #2 on: May 11, 2009, 02:43:50 AM »
Hi Dave,
Now is better, but I'm not satisfied yet.
I set Z axis speed  and acceleration slower, testing a couple of times.
Also I changed resistor value in input divider circuit from 330 Ohm to 680 Ohm
I plan to reduce THC300 electronics reaction time, first to adding capacitor to input from sensor board, and if not satisfactory, to implement integrator circuit (I think).
mrpeja
