Hello Guest it is October 16, 2026, 03:10:22 AM
Author Topic: M01 Optional Stop  (Read 18561 times)
M01 Optional Stop
« on: April 13, 2009, 04:59:09 PM »
Obviously, I don't understand this....  If I have an M01 in my code, and I turn *off* M1 Optional Stop, I expect the M01 line to be skipped, but it's not.  What's the trick?
Also, if I have the following macros:
M991.m1s:
If GetOEMLED(65) = 0 Then
    DoOEMButton(177)
End If
M992.m1s:
If GetOEMLED(65) = 1 Then
    DoOEMButton(177)
End If
I expect the sequence:
M991
M992
M991
M992
To toggle M1 Optional Stop mode, and toggle OEM LED 65.  However, M991 will SET M1 Optional Stop mode, but M992 will NOT clear it!
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: M01 Optional Stop
« Reply #1 on: April 14, 2009, 02:44:12 AM »
Ray -
You could try -
If Not GetOEM(65) Then DoOEMButton(177)
and
If GetOEM(65) Then DoOEMButton(177)
I think the led's are bolean - and the "on" is not necessarily a "1", but it is a non-zero value
« Reply #2 on: April 14, 2009, 09:42:43 AM »
Thanks.  I did figure that out eventually.  Apparently the M1 toggle not working was some random Mach wierdness.  I re-started Mach, and it's now working OK.
« Reply #3 on: February 16, 2010, 03:22:59 PM »
Hey HK - did you every figger out this "random weirdness"?  I sometimes have the same problem.  See post:
http://www.machsupport.com/forum/index.php/topic,14172.0.html
