Mach Discussion => General Mach Discussion => Topic started by: HimyKabibble on April 13, 2009, 05:59:09 PM
Obviously, I don't understand this.... If I have an M01 in my code, and I turn *off* M1 Optional Stop, I expect the M01 line to be skipped, but it's not. What's the trick?
Also, if I have the following macros:
M991.m1s:
If GetOEMLED(65) = 0 Then
DoOEMButton(177)
End If
M992.m1s:
If GetOEMLED(65) = 1 Then
DoOEMButton(177)
End If
I expect the sequence:
M991
M992
M991
M992
To toggle M1 Optional Stop mode, and toggle OEM LED 65. However, M991 will SET M1 Optional Stop mode, but M992 will NOT clear it!
Ray -
You could try -
If Not GetOEM(65) Then DoOEMButton(177)
and
If GetOEM(65) Then DoOEMButton(177)
I think the led's are bolean - and the "on" is not necessarily a "1", but it is a non-zero value
Thanks. I did figure that out eventually. Apparently the M1 toggle not working was some random Mach wierdness. I re-started Mach, and it's now working OK.
Hey HK - did you every figger out this "random weirdness"? I sometimes have the same problem. See post:
http://www.machsupport.com/forum/index.php/topic,14172.0.html
