Hello Guest it is October 20, 2026, 06:01:10 PM
Author Topic: Make Cuts without writing g-code  (Read 11290 times)
MJR
« on: August 02, 2006, 09:55:05 PM »
Hi All:
On occassion all I need to do is cut a straight line on the X or Y axis (to true up a face or for alignment purposes).
Is there a way that I can use Mach3 with out writing a g-code?
Thanks.
Rusty
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: Make Cuts without writing g-code
« Reply #1 on: August 03, 2006, 12:17:43 AM »
You could bump your jog feedrate down to a reasonable speed for the material you need to cut, and hold the jog button down to do it. Another way, but you have to write a SMALL amount of G code, is do it though the MDI text box, e.g., G01 X6 Y0 F3
« Reply #2 on: August 03, 2006, 09:41:31 AM »
Look at the teach wizard in mach3 ... This should help you :)
www.newfangledsolutions.com
www.machsupport.com
