Hello
Guest
it is
October 20, 2026, 03:08:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Make Cuts without writing g-code
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Make Cuts without writing g-code (Read 11286 times)
MJR
on:
August 02, 2006, 09:55:05 PM »
Hi All:
On occassion all I need to do is cut a straight line on the X or Y axis (to true up a face or for alignment purposes).
Is there a way that I can use Mach3 with out writing a g-code?
Thanks.
Rusty
Logged
DAlgie
314
Re: Make Cuts without writing g-code
Reply #1 on:
August 03, 2006, 12:17:43 AM »
You could bump your jog feedrate down to a reasonable speed for the material you need to cut, and hold the jog button down to do it. Another way, but you have to write a SMALL amount of G code, is do it though the MDI text box, e.g., G01 X6 Y0 F3
Logged
Brian Barker
3,860
Reply #2 on:
August 03, 2006, 09:41:31 AM »
Look at the teach wizard in mach3 ... This should help you
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
