Hello Guest it is November 13, 2026, 07:00:04 PM
Author Topic: Webcam plugin with low CPU consumption  (Read 156845 times)
Re: Webcam plugin with low CPU consumption
« Reply #40 on: May 25, 2009, 09:08:58 AM »
Hi Lele
sorry, I can't help you with VB, my knowledge about VB is almost zero. This plugin is developed with Visual Studio 2008 and I don't want to spend to much time in try and error. When the SDK for Visual Studio 2008 is available, I may continue developing the plugin ( I have a solution in mind).  But until then we have to wait.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #41 on: October 18, 2009, 09:53:43 AM »
Klaus,
Is there a way to lock the screen position so it does not need to be reset every time Mach3 is closed and restarted?
Thank You
Jeff...
« Reply #42 on: October 19, 2009, 04:50:05 AM »
Hey Jeff,
I'll see what I can do.
Klaus
« Reply #43 on: October 19, 2009, 08:18:54 AM »
Klaus,
Thank you for the fast reply.
Please keep us posted.
Jeff...
« Reply #44 on: October 21, 2009, 06:44:25 AM »
Hello
sorry, it took a bit longer, but I'm moving over to windows 7 and the first installation didn't work. I implemented the remember position and size feature in version V2.04 which can be downloaded from my website. This feature is switched on if the "remember window positions" checkbox is checked.
Klaus
« Reply #45 on: October 21, 2009, 08:22:34 AM »
Klaus,
Ver 2.04 remembers its position however the cross-hairs do not center.
Thank you for your hard work,
Jeff...
« Reply #46 on: October 21, 2009, 09:48:05 AM »
Hey Jeff
if the checkbox "crosshair centered" is checked in the settings dialog and you size the camera window the crosshair should be centered. To move the camera window be sure the dialog window is greater then the video window.
Klaus
« Last Edit: October 21, 2009, 09:49:51 AM by Klaus1311 »
« Reply #47 on: October 21, 2009, 10:33:01 AM »
Klaus,
The cross-hair will not self center with the remember position enabled.
Jeff...
« Reply #48 on: October 23, 2009, 09:47:58 AM »
Hey Jeff,
I changed the behaviour of the "center crosshair" in version 2.05.
Klaus
« Reply #49 on: October 23, 2009, 04:08:37 PM »
Klaus,
Absolutely perfect, awesome work.
Thank you very much.
Jeff...
