Hello Guest it is November 13, 2026, 07:01:31 PM
Author Topic: Webcam plugin with low CPU consumption  (Read 156864 times)
Re: Webcam plugin with low CPU consumption
« Reply #30 on: May 20, 2009, 01:22:15 PM »
Hi Greg
I 've rebuilt the plugin, actual version is V2.00. Perhaps you can have a look at it and tell me your experience.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline Greolt
  •  956 956
« Reply #31 on: May 21, 2009, 01:55:33 AM »
Klaus
Sorry to say this one seems less stable than the previous versions.
Cross hairs flicker on and off.
Settings will not come up.
Greg
« Reply #32 on: May 21, 2009, 02:06:48 AM »
Hi Greg
OK, in that case I have to finish my machine first, for testing.
Klaus
Offline Greolt
  •  956 956
« Reply #33 on: May 21, 2009, 02:18:08 AM »
Klaus
Yes get your machine finished.
Not sure it will help with debugging this software but you will have more fun playing with it.  ;D
Greg
« Reply #34 on: May 22, 2009, 08:28:38 AM »
Hi Klaus, thank you for your plugin, really well done and useful.
Can you do a version without the blue bar on top ( the bar of the operating system) and around the window ?
I ask fot his improvement because if i can resize the video window at the sane size of the toolpath window i can use a button to recall the webcam that it's shown directly at the same place of the toolpath. With anoter button i can turn off and have it again the toolpath.
What do you think about this ?
Thank you
Lele
« Reply #35 on: May 24, 2009, 07:17:32 AM »
Hi
obviously this plugin works on some machines. For that reason I decided to make yet another version. I optimized the timing and added the possibility to switch off the system menu. Please keep in mind, when the system menu is switched off, you cannot move the window, you have to use the resizing ability instead.
Klaus
« Reply #36 on: May 24, 2009, 08:46:00 AM »
Hi Klaus, thank you for the reply, but i don't undertand if this new version it's yet online or not.
Thank you again for your good job.
Lele
« Reply #37 on: May 24, 2009, 10:07:53 AM »
Hi Lele,
meanwhile I released V2.00.3 ready for download from http://www.kd-dietz.de.  Enabled the "settings" option again and inserted a debug mode (reporting errors)
Klaus
« Reply #38 on: May 24, 2009, 10:42:24 AM »
Thank you very much
Lele
« Reply #39 on: May 24, 2009, 11:05:48 AM »
Wow, work very well ! Thank you.
Now the last question  ;D.
I use a button to open your plugin ( command Sendkeys("PM") ), but i can't figure how i can close your plugin with a VBScript. Can you help me again ?
Because i resize your wonderful plugin to stay exactly in place of toolpath wiindow. I would like to close your plugin window with a button to come back to toolpath.
I will post a screencapture of my screen with your plugin open soon.
Thank you again
Best regards
Lele
