Hello Guest it is October 21, 2026, 02:05:43 AM
Author Topic: Subroutines broken in 42.023  (Read 14955 times)
« on: March 23, 2009, 08:09:04 AM »
Ignores G0 move on next executed line after M99
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Subroutines broken in 42.023
« Reply #1 on: March 27, 2009, 09:18:55 AM »
post your code as I am not sure what your problem is.
Graham
« Reply #2 on: March 27, 2009, 02:57:22 PM »
Attached is one of the programs that is effected.
At return from sub, next move commandis ignored.
Works fine in .021
« Reply #3 on: March 30, 2009, 04:22:35 AM »
It is also broken in Mach3 R3.042.024.
Here is a program that the Z instruction after the macro (line 44 is the first) return doesn't work repeatedly and so I was cutting metal when it shouldn't.
Curt
  •  2,785 2,785
« Reply #4 on: March 30, 2009, 12:14:28 PM »
Try using R3.043.000
Graham
« Reply #5 on: March 30, 2009, 02:34:11 PM »
If I remeber correctly, .43 broke the 4th axis.
I posted that some time ago, but now I cannot find the thread.
Since there is no version change and it is still  .43.00, I assume it is still bropken?
It seemed the thrust behind 43.023 and .24 was to fix threading. Does threading work in 43.00?
