Hello
Guest
it is
November 19, 2026, 09:04:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Pause/Feedhold LED broken again?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Pause/Feedhold LED broken again? (Read 33811 times)
Greolt
956
on:
March 09, 2009, 03:43:56 AM »
In November (3.042.018) we got the pause/feedhold LED fixed after such a long
time.
In January (3.042.021) it appears it might be broken again.
Greg
Logged
ger21
6,295
Re: Pause/Feedhold LED broken again?
Reply #1 on:
March 09, 2009, 08:01:37 AM »
I tried it recently and it didn't work for me either.
Logged
Chaoticone
5,624
Precision Chaos
Reply #2 on:
March 09, 2009, 02:47:00 PM »
Greg, are you talking about OEM LED 805? I'm testing and trying to help verify. Are you setting the led up as system function "Pause" or useing an oem code?
Last Edit: March 09, 2009, 02:51:27 PM by Chaoticone
Logged
If you could see the things I have in my head, you would be laughing too.
Greolt
956
Reply #3 on:
March 09, 2009, 04:05:59 PM »
System function "pause"
OEM LED 80 "Pause Active LED"
OEM LED 805 "Pause LED"
OEM LED 111 "Feedhold when part of a block executed - remainder pending LED"
None of these will work for me with Ver 3.042.021
The other thing is that the "Run" LED does not go out when in feedhold either.
As far as I know all the above worked in Ver 3.042.020
Greg
Logged
Greolt
956
Reply #4 on:
March 09, 2009, 04:30:05 PM »
Reinstalled Ver 3.042.020 and all work as expected except for OEM LED 80
So despite that Brian says he tested it and it's working. It is not working for me.
Greg
Logged
Chaoticone
5,624
Precision Chaos
Reply #5 on:
March 09, 2009, 04:53:22 PM »
OK, thanks Greg
Logged
Chaoticone
5,624
Precision Chaos
Reply #6 on:
March 09, 2009, 05:03:27 PM »
Greg, I just tested an exe and it works a treat
. System function and all 3 leds.
Logged
Greolt
956
Reply #7 on:
March 09, 2009, 05:49:57 PM »
OK thanks Brett.
That just proves I am doing something silly.
Just to confirm, you tested in Ver 3.042.021
Maybe I will do a fresh download of that version and try again.
Greg
Logged
Chaoticone
5,624
Precision Chaos
Reply #8 on:
March 09, 2009, 05:53:36 PM »
No Greg, you were right. I have been testing a new, yet to be released exe and it is fixed up in it.
Logged
Greolt
956
Reply #9 on:
March 09, 2009, 06:07:09 PM »
Glad to know I am not loosing my marbles.
Re down loaded and installed Ver 3.042.021 and they don't work.
Guess I need to stay with the lockdown version.
Greg
Logged
Print
Pages:
1
2
Go Up
« previous
next »
