Hello
Guest
it is
October 21, 2026, 12:04:41 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
General CNC Chat
Show"N"Tell ( What you have made with your CNC machine.)
Miser engine
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Miser engine (Read 86030 times)
edvaness
506
Re: Miser engine
Reply #10 on:
February 24, 2009, 09:33:21 PM »
Vince,
Its only supported in the front. The front panel is .250 Alum plate. The bottom is tapered in about an inch above the base.
the bottom is attached to the back panels and the front panel which has the legs. I wanted enough room under to shove my shop vac and 5 gal pails out of the way.
ED
Logged
Ed VanEss
Tweakie.CNC
9,374
Super Kitty
Re: Miser engine
Reply #11 on:
February 25, 2009, 06:48:10 AM »
Hi Vince,
Sorry to hear about the work slow down. Very nice sterling you are making there.
Logged
N4NV
398
Re: Miser engine
Reply #12 on:
February 25, 2009, 05:54:58 PM »
I been sitting around with a cold but decided to work in the garage anyway. I made up the balance disk. There is a small hole that is .7" deep that needs to be tapped 2-56. My 2-56 tap is about 5 threads short. I will have to go to the tool supply shop and see if I can get a longer one.
Vince
Logged
Re: Miser engine
Reply #13 on:
February 25, 2009, 07:57:19 PM »
Vince,
Nice going on the Miser. Surely gets the mind off of other things.
Logged
Tweakie.CNC
9,374
Super Kitty
Re: Miser engine
Reply #14 on:
February 26, 2009, 01:13:52 AM »
Vince,
As the hole is for a grub screw couldn't the hole be counter bored, say,the diameter of the tap shank then only tapped for the length of the grub screw ?. This could save the expense of buying a special, long tap.
Logged
Overloaded
4,923
Re: Miser engine
Reply #15 on:
February 26, 2009, 06:41:31 AM »
................and the likelihood of breaking it off (if I were to try it).
RC
Logged
N4NV
398
Re: Miser engine
Reply #16 on:
February 26, 2009, 07:23:00 AM »
I thought about counter boring. The tap shaft is .140" and the part is .250 thick. That would leave me .055" for a wall thickness, which probably wouldn't matter. I don't have a mill that size, I would have to do it with a drill. In the instructions supplied by Howell, he does not mention counter boring so I am assuming there is a tap out there that can do it.
Vince
Logged
Overloaded
4,923
Re: Miser engine
Reply #17 on:
February 26, 2009, 07:27:48 AM »
Vince,
Another option you might use is to just tap the first portion of the hole, then insert a brass plug under the set-screw to clamp against the shaft. Also prevents the screw from marring the shaft.
RC
Logged
N4NV
398
Re: Miser engine
Reply #18 on:
February 26, 2009, 07:32:03 AM »
I thought about that as well. That is how most of the set screws on my Hardinge CHNC are set up.
Vince
Logged
N4NV
398
Re: Miser engine
Reply #19 on:
February 26, 2009, 07:32:24 PM »
I got two days work, Thursday and Friday so I won't get anything done until the weekend. I did stop by the tool store and it seems no one makes a pulley tap in 2-56 threads so it looks like I will counter bore.
Vince
Logged
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
