Hello Guest it is November 22, 2026, 07:03:42 AM
Author Topic: wiring up MPG  (Read 17055 times)
wiring up MPG
« on: December 24, 2005, 10:37:57 AM »
HI ALL
NEED SOME HELP WITH WIRING MY NEW MPG
PINS NEEDED   FOR +5V
PIN  FOR     OV
PIN FOR    A
PIN  FOR   B
PRINTER PORT 2 IS IN  PC
WILL ALL PINS BE ON PORT 2
Re: wiring up MPG
« Reply #1 on: December 26, 2005, 07:34:39 AM »
You are going to have to find the 0 and 5 V power... Some of the breakout boards have the 5V power on them and some do not. I have hooked into the computer power supply in the past or testing...
The pins for the A and B channels can be hooked to what you have set on the ports and pins page. There is a tab called "Encoder" where you set the pins.
Hope that helps
www.newfangledsolutions.com
www.machsupport.com
