Hello Guest it is November 13, 2026, 01:45:20 PM
Author Topic: OEM for M5?  (Read 13450 times)
OEM for M5?
« on: February 06, 2009, 08:46:56 AM »
I can't seem to find an OEM for a M5/spindle stop function.  Does anybody know?
Tom
Re: OEM for M5?
« Reply #1 on: February 06, 2009, 09:59:27 AM »
Can't you just use Code "M5"?
Re: OEM for M5?
« Reply #2 on: February 06, 2009, 10:33:50 AM »
I'm not sure?  I am retrofitting a 1985 compumill and on the control panel there is a spindle stop button  that I would like to hook up though Mach.  The spindle CW and CCW buttons are are hooked up this way with OEMs  so I can turn on the spindle from the control panel or the screen.(I can turn them off by pushing the button again,  but would like to use the assigned button.)
Can I just put M5 in the OEM setup page?
Tom
Re: OEM for M5?
« Reply #3 on: February 06, 2009, 12:33:08 PM »
You can add a button to the screen, and assign M5 to it, and set up an OEM trigger for the external switch.
