Hello Guest it is November 13, 2026, 12:39:39 PM
Author Topic: Mach3 unable to locate component  (Read 14946 times)
Offline Glenn
  •  129 129
« on: December 31, 2008, 01:58:24 PM »
Hi guys,
  Here's a message you don't want to see when clicking on
your desktop icon for Mach 3 Mill! :'(
  " This application has failed to start because ATL71-DLL was not found.
 Re-installing the application may fix this problem."
  My system has been running GREAT but today, not so much...
   Has anyone seen this problem or know of a solution before I try to re-install Mach?
    Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
Re: Mach3 unable to locate component
« Reply #1 on: December 31, 2008, 02:42:03 PM »
Have attached the ATL71 from my Mach folder, might be ok just to paste it in, if not then a reinstall should do it. You will need to change the file extension back from .txt to .dll  as I changed it so the forum would accept it.
Offline Glenn
  •  129 129
« Reply #2 on: December 31, 2008, 05:08:55 PM »
Thanks Hood!
   I'm good as new, makin' some chips fly!
      :) :D ;D
« Reply #3 on: December 31, 2008, 05:13:50 PM »
      :) :D ;D
Glad to hear that as I am getting dizzy watching you running round that tree, now you are back at your machine I should be ok.
