Hello Guest it is June 10, 2026, 01:01:44 AM
Author Topic: Is it true about Galil plugin?  (Read 117004 times)
Re: Is it true about Galil plugin?
« Reply #40 on: July 25, 2008, 05:09:21 AM »
Sure...
Me too..
But if I hit ref all before a program is loaded it works every time.. If it is after a program and I hit ref all sometimes it works like a charm and sometimes it don't.
Hey THANKS 4 all the help in advance. I'll need more than you'll ever expect!!!
www.cravenpottery.com
« Reply #41 on: July 25, 2008, 05:58:55 AM »
Mmmm, That is interesting. Mine seems to do it at any point and then sometimes it works fine?????
I am going to try a different PC and see what happens. I am using one of the MachMotion PC's now.
Did yours get better after updating the software to R3.041?
Darek
« Reply #42 on: July 25, 2008, 08:50:43 AM »
Hello,
That is odd... Could you please see if you jog before you home if that will fix it? I am thinking that we have a mode in the Galil that is not getting set and jogging may set it :)
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #43 on: July 25, 2008, 05:24:25 PM »
Yes and no? But me changing computers would be a headache and a half.....
Brian I will try that as soon as I get time away from my office.pluuuu...
« Reply #44 on: July 27, 2008, 07:50:36 AM »
Brian,
The travels are long on this machine so we usually jog it close to the switches before homing. When it hangs I have to exit  and restart Mach3 before it will attempt to home again. I have to jog off the home switch at this point to re-home. I am using external buttons through Modbus, brains and OEMButtons to jog, don't know if that makes a difference.
Pointcloud,
I read where you have the PCI card. I am using the DMC-2183 with ethernet connection. Trying a different PC will be allot easier for me.
Darek
« Reply #45 on: July 27, 2008, 10:12:43 AM »
That seems odd.. I would think that may be a noise problem.. we could make a bit of code to test the inputs and tell if they ever see the input go high...
Brian
www.machsupport.com
« Reply #46 on: July 27, 2008, 01:44:55 PM »
Just ESC instead of exiting? That way you will not loose positioning? Or your offsets????
Still have not made it back to the shop....
« Reply #47 on: July 29, 2008, 02:39:03 PM »
ESC will let it jog again but it will not try to home again untill I exit Mach. If I try home after ESC it will not jog until I hit ESC again.
I will check for noise also. I am using the opto board which specs 1mA for input current, approximately 2v but I have found they will trigger at lower voltages.
Darek
« Reply #48 on: July 29, 2008, 02:51:42 PM »
Sounds to me like I should be able to fix it in code too.. You should be able to press Escape and have that fix it!...
I need to take the Galil test board down to the router and hook it up.. Could you please tell me what you are doing to make it fail?
Brian
www.machsupport.com
« Reply #49 on: July 29, 2008, 04:32:33 PM »
Wow.. Esc worked for me?
I will be running a part Friday, I hope... So I'll see what happens in my case...
