May 28, 2012, 11:39:08 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Works in progress
| | | |-+  3 Axis Simple Screen setup 1.0 (Also good for TouchScreens)
Pages: « 1 2 3 4 5 6 7 8 9   Go Down
Print
Author Topic: 3 Axis Simple Screen setup 1.0 (Also good for TouchScreens)  (Read 45318 times)
joyride
Active Member
Offline Offline
View Profile WWW
« Reply #80 on: April 25, 2008, 02:14:04 AM »
Hi Zealous. Are you still deveolping/supporting this screenset? The download above displays half page on the left and the jog screen is tiny. Trying to ply with resolutions now. Alto the files suggest a talk or speech option? Best, Rob
Loui
Active Member
Offline Offline
View Profile
« Reply #81 on: September 05, 2008, 04:16:13 PM »
Any chance you could add a spindle button and a coolant button to the material tab? Thanks Loui
fever16
Active Member
Offline Offline
View Profile
« Reply #82 on: September 18, 2008, 09:15:35 AM »
looking forward for final release of this screen.
Edit-G code worked fine for me.but jog is a real problem.
except this rest is awesome.
fever16
Active Member
Offline Offline
View Profile
« Reply #83 on: September 18, 2008, 09:16:50 AM »
and as Loui said,
spindle control is required.(coolant might not be that impotent )
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #84 on: September 30, 2008, 10:38:41 AM »
Very sorry about the delay...
I will make those additions and fixes...give me a a bit to finish them up and I will update and post it here.
Thank you
Regards, Jason Blake
www.Fusioncnc.com
dinko
Active Member
Offline Offline
View Profile
« Reply #85 on: December 27, 2011, 05:12:19 AM »
hi... this is the best screen set i ever have but...
i dont find a button for auto zero tool!!  how can use this function on this screeen set ??
Pages: « 1 2 3 4 5 6 7 8 9   Go Up
Print
Jump to:
