Hello
Guest
it is
June 12, 2026, 01:12:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
mach3 ssetup
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: mach3 ssetup (Read 17457 times)
komar1970
111
Re: mach3 ssetup
Reply #10 on:
September 17, 2011, 11:20:38 AM »
the parts is 40mm x 40mm inside hole 30mm
after i fix the big problem onli is problem with one X axis
parts cut out dimensions 40mm Y axis hole 30mm and X axis 40.20mm only the X AXIS is problem
komar1970
111
Re: mach3 ssetup
Reply #11 on:
September 17, 2011, 11:26:02 AM »
Who will help me set this MACH3
Carnoustie, Scotland
Re: mach3 ssetup
Reply #12 on:
September 17, 2011, 01:44:08 PM »
Are your steps per unit correct?
komar1970
111
Re: mach3 ssetup
Reply #13 on:
September 17, 2011, 06:19:21 PM »
i have ste to 400 and I lined up in a mach 3, but it's improved
komar1970
111
Re: mach3 ssetup
Reply #14 on:
September 17, 2011, 06:31:06 PM »
i fix the problem thanks hood for help is work perect if i cut 70mm x 40 hole 20mm is ok perfect size if i cut 40 x 30 hole 1 perfect if i cut 340mm x 140 hole 50mm smole proble it is 340.01 that is ok
Re: mach3 ssetup
Reply #15 on:
September 18, 2011, 02:56:00 AM »
Glad to hear it
Print
Pages:
1
2
Go Up
« previous
next »
