Hello Guest it is June 10, 2026, 08:24:20 AM
Author Topic: G73 Pullback setting  (Read 8034 times)
« on: September 09, 2011, 12:32:15 PM »
Could someone verify that the G73 pullback setting is NOT being saved in the XML when you change it .
Config , port/pins, mill options, lower center of window.
Thanks (;-) TP
Re: G73 Pullback setting
« Reply #1 on: September 09, 2011, 01:11:35 PM »
I am sure I have seen mention of that before and have just confirmed it is the case.
« Reply #2 on: September 10, 2011, 05:44:57 PM »
It is not saved. It looks like the XML file is updated with the value 0.1 when you exit Mach3.
