Hello
Guest
it is
June 11, 2026, 03:07:54 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Anyone running a CNCshark with Mach3?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Anyone running a CNCshark with Mach3? (Read 7768 times)
Greolt
956
on:
June 04, 2010, 05:39:13 AM »
I believe it is using an NCpod which should be no problem to run with Mach.
Greg
Tweakie.CNC
9,356
Super Kitty
Re: Anyone running a CNCshark with Mach3?
Reply #1 on:
June 04, 2010, 07:41:31 AM »
Hi Greg,
I thought the CNCshark was USB driven.
If you can you get access to the driver card for parallel connection then I think it would be possible to drive the machine from Mach3.
Greolt
956
Reply #2 on:
June 04, 2010, 07:53:48 AM »
Yes it is USB driven.
As far as I know it is using an NCpod. Mach has a plugin for that.
In theory it should just be a matter of plug it in and go. I have used NCpod in the past.
Just wondered if any body was doing it.
Greg
Print
Pages:
1
Go Up
« previous
next »
