Hello Guest it is June 09, 2026, 10:05:07 PM
Author Topic: Pokeys Disabled ?  (Read 49125 times)
Re: Pokeys Disabled ?
« Reply #20 on: March 03, 2010, 02:00:16 PM »
Ok Phil, have used the latest PoKeys software and it is working fine, tried with your xml and you have active High selected so unless your switch is NC you need to change that. Still not tried with the latest plugin so will try that in a few mins but working fine so far :)
« Reply #21 on: March 03, 2010, 02:35:41 PM »
Ok last report, got the latest pluhgin installed and its working fine so not sure where your problem lies unless its because you have a NO switch and have active High chosen, if your switch is NO then it should be Active Low.
« Reply #22 on: March 03, 2010, 04:21:04 PM »
Thanks for your help i have now got it working. ;D
Phil
« Reply #23 on: March 03, 2010, 04:40:01 PM »
« Reply #24 on: March 03, 2010, 05:34:28 PM »
Thanks to Scott as well, keep your head down mate. ;)
Phil
« Reply #25 on: March 04, 2010, 11:26:14 PM »
Hey Hood, Phil,
   Sorry about that then, I guess it has changed the last time I dealt with external jog keys, (on the 6 axis jog plugin), when the key was active I had to make it jog, when the key was unactive I had to tell it to quit.
sorrry about my error gents..........
scott
« Reply #26 on: March 05, 2010, 04:36:01 AM »
scott
Not sure who that is meant for, I am certainly not a gentleman ;D and Phil is English so definitely not him ;D ;D
« Reply #27 on: March 05, 2010, 06:37:49 AM »
 :D ;D
« Last Edit: March 05, 2010, 06:40:10 AM by Overloaded »
« Reply #28 on: March 05, 2010, 07:09:20 AM »
I'll ave you Butler. ;D
Phil
« Reply #29 on: March 05, 2010, 07:29:18 AM »
;D
