Hello Guest it is October 20, 2026, 10:49:34 PM
Author Topic: How do I reverse the x-axis direction of travel?  (Read 128153 times)
Bagpipes
Re: How do I reverse the x-axis direction of travel?
« Reply #10 on: July 16, 2006, 12:02:52 PM »
Leeway I bet you have been waiting months for the right thread to use that line in!! :-)
Anyway - I'll update this thread with my Mach3 fixes. Hopefully that'll do the trick. Thanks for the help so far Hood!
Steve Nuttall
« Reply #11 on: July 17, 2006, 05:34:36 AM »
swap 2 of the wires from 1 phase on the stepper motor
it will reverse
Bagpipes
« Reply #12 on: July 17, 2006, 05:18:22 PM »
OK - I loaded Mach3 without uninstalling Mach2. Mach2 still jogs the table around but I can't get any movement using Mach3. I checked the driver test and that looks good. x y and z motor outputs are all checked green. Any ideas?
« Reply #13 on: July 17, 2006, 06:20:19 PM »
Check the port number of teh step and direction pins :) It comes set to zero and I think you will need to put in ones.
www.newfangledsolutions.com
www.machsupport.com
Bagpipes
« Reply #14 on: July 17, 2006, 09:08:51 PM »
This what's on my current setup
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #15 on: July 17, 2006, 09:37:13 PM »
Hi Bagpipes
Under Config - Motor Home/Soft Limits, Check the Reversed column for the Axis you need to revers.
Chip
« Reply #16 on: July 18, 2006, 12:36:59 AM »
Bagpipes
In the screenshot you have above you dont have any ports set for step or direction, you need to enter 1 in each of the port boxes. Then if an axis is moving the wrong way you can change the Dir low acive for that axis and it should reverse.
Edit
 OOPS, sorry Brian, never noticed you already said about the port number.
« Last Edit: July 18, 2006, 12:46:53 AM by Hood »
Bagpipes
« Reply #17 on: July 18, 2006, 10:38:29 AM »
A thousand thank-yous, guys. I am determined to get this machine to move today - even if it's in the wrong direction!!
« Reply #18 on: July 18, 2006, 11:06:16 AM »
Just a bit curious why you are called bagpipes, are you from Scotland?
Bagpipes
« Reply #19 on: July 18, 2006, 11:23:42 AM »
Yes - good guess laddie - I am indeed from Scotland. Born and bred in Inverness.
