Hello Guest it is November 11, 2026, 06:33:20 AM
Author Topic: Some information about port 2  (Read 14144 times)
« on: December 28, 2008, 10:18:44 AM »
hello, as I wish to use some rotary encoders for MPGs, those:
http://it.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=263-2889&x=15&y=10
and I want use port 2 pins 2-9 that are described on manual as CMOS thresholds inputs, I wish to know if it mean have 1 level to 12 volts or 5? If I will use the CD4504 TTL to Mos translator can I assume it will do the work?
Thanks in advance
« Last Edit: December 28, 2008, 10:20:46 AM by pedro »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Some information about port 2
« Reply #1 on: December 28, 2008, 01:53:00 PM »
you should be able to connect this with a 5 volt supply and connect it straight to the breakout board.
Or have a look at these, these work even better
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=15&products_id=30
Graham
« Reply #2 on: December 28, 2008, 04:54:26 PM »
thank you very much for the help and prompt answer. I realy already have some of the encoders I posted, I will try with them
