Hello Guest it is September 12, 2026, 07:21:38 PM
Author Topic: Setting up inputs  (Read 14211 times)
Setting up inputs
« on: July 14, 2006, 11:38:28 AM »
Need help on setting up inputs. I  can't unlock limit switches even after checking active low switches.
Re: Setting up inputs
« Reply #1 on: July 14, 2006, 12:37:22 PM »
set the input to be a limit switch so you can see the state on the diagnostics page. Now toggle the input and see if you can see the state change on the diagnostics page. IF the state is not changing there is something wrong in the wiring. If the LED is changing we can start testing some software :)
www.newfangledsolutions.com
www.machsupport.com
