Mach Discussion => General Mach Discussion => Topic started by: gearcutter on July 14, 2006, 12:38:28 PM
Need help on setting up inputs. I can't unlock limit switches even after checking active low switches.
set the input to be a limit switch so you can see the state on the diagnostics page. Now toggle the input and see if you can see the state change on the diagnostics page. IF the state is not changing there is something wrong in the wiring. If the LED is changing we can start testing some software :)
