Hello Guest it is November 13, 2026, 11:48:06 AM
Author Topic: Mach3 settings  (Read 13131 times)
Mach3 settings
« on: December 19, 2008, 09:26:17 AM »
I have read the documentation, but I'm not sure about some settings.
I have a 269 oz. stepper motor with 200 steps and set the jumpers to 1/8 microstep - thus 1600 steps.
The lead screw is 1/4-20 allthread.
Under motor tuning, do I enter 1600 steps or (1600 x 20)?
Also I have a XP desktop 1.2 ghz computer.  I have been running Mach 4 at 25,000hz.  Should I try 35,000 or greater?
I built a wood cnc router table using Rockcliff Model A plans and am using 269 oz. in. motors.
Can anyone tell me what kind of velocity and acceleration that others have used?
Thanks for your help.
« Last Edit: December 19, 2008, 09:27:48 AM by dave63021 »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Mach3 settings
« Reply #1 on: December 19, 2008, 12:50:15 PM »
Hi, Dave
32.000 steps per should do it, Vel & Acl values, Start low and increase till you get a feel for your Machine, Say vel 20 Acl 5 to start with.
I'd leave it at the 25 K for now.
Hope this Helps, Chip
Re: Mach3 settings
« Reply #2 on: December 19, 2008, 12:52:29 PM »
You enter 32,000 for steps per unit.
If you need more speed than 25KHz will give you (46.875ipm) then you will need to go to a faster Kernel. 35KHz would potentially give you 65.625IPM and 45KHz 84.375IPM.
 Whether you will achieve these speeds I dont know but trial and error will give you that answer :)
