Hello Guest it is October 23, 2026, 03:44:40 AM
Author Topic: Tool Offset Doesn't Work?  (Read 16156 times)
Malorie
« on: July 10, 2006, 03:27:43 PM »
I am trying to get Mach 3 to change the tool height for the various tools that I set up in the offsets screen and it just doesn't seem to want to do it. I'm sure I'm missing sometheng simple, but for the life of me I can't figure out what.
On the tool offset screen, the "Tool Offset On/Off" LED is lit for the tools with offsets and the offsets are entered in the "Z Offset" DRO for each tool. My G-code has the M6 T(tool number) in it. When I rung the program and it reaches a tool change, Mach 3 pauses and says "Press Cycle Start After Tool Change" with the "Change Tool" LED flashing. The indicated offset shows up in the "Tool Information" panel, but the offset just never happens, before or after pressing cycle start.
I'm at a loss,
Malorie
Re: Tool Offset Doesn't Work?
« Reply #1 on: July 10, 2006, 03:32:35 PM »
You need a G43 H(Tool number) That should get you working
www.newfangledsolutions.com
www.machsupport.com
Malorie
« Reply #2 on: July 10, 2006, 03:43:20 PM »
That's got it!! :D
I knew it would be some newbie thing. :)
Thanks for the quick response. :)
Happy machining,
Malorie
