Hello Guest it is November 22, 2026, 08:26:28 AM
Author Topic: RPM Display  (Read 16190 times)
RPM Display
« on: December 05, 2008, 06:22:10 PM »
I have a spindle with two pulses per rev.  I'm reading this into the "index" input, so the RPM counter always displays twice the actual RPM.
Is there a way to divide the pulse inputs to display a proper speed?
Re: RPM Display
« Reply #1 on: December 06, 2008, 04:47:27 AM »
You can use the timing input instead but you will need one slot widerthan the other.
Re: RPM Display
« Reply #2 on: December 06, 2008, 09:41:06 AM »
Hood,
    I'm no macro weenie, but couldn't he overlay the RPM display with another DRO, and have a macro, or perhaps even a brain, that reads the "real" RPM DRO, divides by two, and uses that value to update the new DRO?
Re: RPM Display
« Reply #3 on: December 06, 2008, 10:05:01 AM »
Thinking about it Ray I think Mach can actualy do this itself by using the ratios, forgot all about that :)
Re: RPM Display
« Reply #4 on: December 06, 2008, 10:23:47 AM »
How do you mean ratios?
My spindle is set to run at 6,000 RPM which gives 12,000 pulses.  I tried to set the pulley #1 ratio at 2, but the RPM stayed the same in the display (12,000).  There is a box in the spindle calibration pop-up that says "pulses per revolution", but it is grayed out and I can't enter the number two there.
How else would you do this?
Re: RPM Display
« Reply #5 on: December 06, 2008, 10:29:37 AM »
Not done it myself but think it should be in the manual, if you cant find it come back and I am sure someone that has used it wil advise.
