Hello Guest it is October 21, 2026, 08:05:30 PM
Author Topic: Well i finally uploaded my 6 axis screen, was 5 axis.......  (Read 240071 times)
Offline BarryB
  •  267 267
Re: Well i finally uploaded my 6 axis screen, was 5 axis.......
« Reply #20 on: January 10, 2010, 10:53:46 AM »
I think there is a bug in the home switches with this screenset.  Specifically B and C home switches.  One of those turns on the LED for both, and the other won't turn on an LED at all.  I haven't tested the A axis as that part of my machine won't be up and running for a while.
Is there a way we can amend this set too?  Having a button to reference all axis is dangerous on my system.  I can only do that for X, Y and Z.  The other axis, I have to reference by hand.  I'd also like to take off the reverse spindle option.
Barry
« Reply #21 on: September 27, 2010, 01:16:48 PM »
Found a small bug in the 6 axis screenset.  The "zero C" button does not function.
Otherwise, looks great!
As you'll see I got lazy and didn't finish it all, most of it is done though, I'd like to make sure most of it works before I change some of the other pages around.
Let me know your thoughts or ideas and maybe I can implement them.
Im sure you are all aware to copy the folder into Mach3\Bitmaps and the 6 axis screen into \Mach3.
I made it 6 axis, because it's easier to remove a couple of axis than it is to add them.
« Reply #22 on: May 04, 2011, 06:30:34 PM »
I've very near completed a five axis router, XYZBC, I'm using this six axis screen set for testing, Thanks for posting it!
When I open the MPG/jog screen I get XYZ 4th jog control buttons.
Should I be seeing XYZABC?
Do you/anyone have some advise for me
Liam.
« Reply #23 on: March 03, 2013, 02:19:46 PM »
when you click the "-" button on spindle speed it doesn't slow spindle... it just turns it off!
« Reply #24 on: June 03, 2019, 06:57:35 AM »
Hi Tarak,
I added the C axis inhibit button and the LED to go with it on the settings page. The button works but the LED does not any idea what I've done wrong?
Also, it's quite common for the page tabs across the top of the screen to stop responding to mouse clicks, the alt number keystroke always work, do you know if this can be fixed?
Splint
Offline TPS
  •  2,627 2,627
« Reply #25 on: June 03, 2019, 11:47:02 AM »
Axis inhibited C LED is 91 in my list? not 90
« Reply #26 on: June 03, 2019, 01:21:39 PM »
I temporarily put it at 90 to see if it would respond to a change in the B axis inhibit but it doesn't work for 90 or 91.
Offline TPS
  •  2,627 2,627
« Reply #27 on: June 04, 2019, 01:18:53 AM »
tested here (in 1024 Standard srceen set) OEMButton255 OEMLED91 worked.
i have used machscreen.
« Reply #28 on: June 04, 2019, 02:15:59 AM »
Thanks TPS, that's interesting. I used Screen4 to add the C axis button and LED. I've attached the set file, any chance you could test it on your computer and see if it works or not? Modified in 1024*768.
Splint
« Last Edit: June 04, 2019, 02:18:53 AM by Splint »
Offline TPS
  •  2,627 2,627
« Reply #29 on: June 04, 2019, 02:18:46 AM »
i Need your Bitmaps as well
