Hello Guest it is November 23, 2026, 03:14:29 PM
Author Topic: Very slow jog  (Read 15501 times)
Offline Freff
  •  12 12
Very slow jog
« on: November 29, 2008, 02:57:51 PM »
I've done something wrong or inadvertently reset something, but I just can’t figure out what it is. Everything was running fine until I tried to jog to a new position. The machine jogs so slow it's painful. Actual cutting is no problem and it appears to run as normal. The jog rate is set to 100%. I have increased Vel and Acc, the pulse rates and debounce to no avail. I have tried it in both inches and metric, the same.
I'm at a lose to think of anything else at the moment, perhaps someone could help me out with this please.
Thanks Tony
Re: Very slow jog
« Reply #1 on: November 29, 2008, 03:17:20 PM »
Can you attach your xml please.
Offline Freff
  •  12 12
Re: Very slow jog
« Reply #2 on: November 29, 2008, 04:30:20 PM »
Here you are Hood.
Re: Very slow jog
« Reply #3 on: November 29, 2008, 04:35:27 PM »
Thanks but afraid that seems to be the wrong XML or its corrupt :( Please try again.
Offline Freff
  •  12 12
Re: Very slow jog
« Reply #4 on: November 29, 2008, 04:43:10 PM »
I'm having trouble uploading it. Keeps telling me file already exist. How do I correct or shall I email it to you.
Tony
Re: Very slow jog
« Reply #5 on: November 29, 2008, 04:48:41 PM »
Have sent you a PM but just for your information the forum will only accept a file once so if one of that name has already been attached you need to rename your file and try again.
