Hello Guest it is November 13, 2026, 08:00:15 PM
Author Topic: Help getting set up  (Read 94138 times)
Re: Help getting set up
« Reply #50 on: November 15, 2008, 06:08:18 PM »
OK so  we know Mach is OK, your port is OK, your cable is OK so now check on the output side of the C10 and that will show whether the signals are passing through it. If they are not then double and tripple check it is wired correctly and if still not getting them then the C10 looks suspect.
Offline Rob27
  •  25 25
« Reply #51 on: November 15, 2008, 06:23:27 PM »
When I checked on the cable pins, I can get to the 3 and 25, but with the cable hooked up, I can get to the 3, but where do I get to the 25 pin?
« Reply #52 on: November 15, 2008, 06:43:48 PM »
From the common connector beside the pins connector.
Offline Rob27
  •  25 25
« Reply #53 on: November 15, 2008, 06:54:13 PM »
From here I read between 0 and .5v dc, with only the power from the printer cord... With everything on, I get 4.75v dc, going in either direction...
« Last Edit: November 15, 2008, 06:57:06 PM by Rob27 »
« Reply #54 on: November 15, 2008, 07:03:21 PM »
Well either your BOB is bad or your wiring is bad. If you still cant get it after checking the wiring your best bet is to contact Arturo and see what he suggests as a test.
Offline Rob27
  •  25 25
« Reply #55 on: November 15, 2008, 09:24:59 PM »
Success!!! All motors are running, and dialed in! A couple of pins on the BOB was the culprit!
« Reply #56 on: November 16, 2008, 02:24:43 AM »
Great news :)
