Hello
Guest
it is
October 30, 2026, 02:15:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Throwing a switch with Mach2
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Throwing a switch with Mach2 (Read 14924 times)
widpyro
91
on:
July 06, 2006, 06:33:34 PM »
Mach2 runs my motors perfectly and I would now like to operate some switches within the program. What is the easiest way to do this?
Brian Barker
3,860
Re: Throwing a switch with Mach2
Reply #1 on:
July 07, 2006, 07:48:39 AM »
You would like to turn on outputs? If that is the case there is a section in the mach2 manual showing you how to do this. Search the PDF for "output" and you should find it. if you have any trouble we are here!
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
