Hello Guest it is October 30, 2026, 01:29:01 PM
Author Topic: Throwing a switch with Mach2  (Read 14922 times)
« on: July 06, 2006, 06:33:34 PM »
Mach2 runs my motors perfectly and I would now like to operate some switches within the program. What is the easiest way to do this?
Re: Throwing a switch with Mach2
« Reply #1 on: July 07, 2006, 07:48:39 AM »
You would like to turn on outputs? If that is the case there is a section in the mach2 manual showing you how to do this. Search the PDF for "output" and you should find it. if you have any trouble we are here!
www.newfangledsolutions.com
www.machsupport.com
