Hello Guest it is October 20, 2026, 05:05:53 PM
Author Topic: Circlular Pocket Problem and mach3 setup  (Read 15885 times)
« on: October 30, 2008, 04:53:18 AM »
Hello everyone I am a new user of CNC and mach3
I have a question if anyone could help.
I use solidcam and generate Gcode for a circular pocket cut.
As my mach3 was setup by the distibutor of Syil in Greece when I load the Gcode it shows this:
And when I upload the gcode to an unsetuped version of Mach3 it shows correctly the circular pattern of the pocket cut.
It is really confusing because I am a new user and do not know where to check for error.
But I believe it is in the setup of Mach3 as it loads and shows correctly the path on another mach3 istallation
Re: Circlular Pocket Problem and mach3 setup
« Reply #1 on: October 30, 2008, 06:44:55 AM »
I dont know If I made it clear.
But what I mean is that
when it loads on another mach 3 the work offsets are Y-17  +17
and on the other version is Y-17 +51 it seems that is doesnt center properly
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: October 30, 2008, 06:46:49 AM »
Not sure what you are saying, have you set your datums?
Graham
« Last Edit: October 30, 2008, 06:48:21 AM by Graham Waterworth »
« Reply #3 on: October 30, 2008, 02:09:56 PM »
Dear Graham ,
Thank you very much for your help through your email as well.
It was indeed the IJ mode I switched to Inc and it loaded perfectly!
The problem was it loaded other programs (linear pocket cutting) perfectly
but not on the circle pocket from inside to outside w overlap pocket cut.
Now everything is fine and Im up and running on my new miniCNC
Thank you again!!
« Reply #4 on: October 30, 2008, 02:54:44 PM »
