Hello Guest it is October 20, 2026, 03:01:07 PM
Author Topic: What was upgraded in R3.042.015  (Read 12873 times)
« on: October 25, 2008, 08:43:55 PM »
I can seem to find what bug fixes were done in version R3.042.015n
Iam hoping that CV for tangential axis has been implemented.
Jason
Re: What was upgraded in R3.042.015
« Reply #1 on: October 26, 2008, 05:00:50 AM »
Dont think that has been done, the last few Dev versions have been fixing the long running VB interface problems, lathe threading and a few other odds and ends. Think there will be a list of fixes when it becomes a lockdown.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: October 26, 2008, 05:12:30 AM »
Cutter comp is at the top of the to do list according to Brian.
Graham
« Reply #3 on: October 26, 2008, 08:33:14 AM »
Brian:
Just downloaded and ran 3.042.015 and have the same issue previously reported regarding 3.042.004 (see below).  The part was cut correctly, but looking at the weird numbers in the Tool: Table Display screen was really disconcerting.  Have gone back (again) to 3.041.
Previous post follows:
Downloaded and ran 3.042.004 version and had nothing but problems.  Code that ran perfectly in version 3.041 would not run without problems in arcs, etc.  One thing I noticed on the Diagnostics screen is the abs max x, y, z were all out of proportion to the drawing in the code in mill mode.   The figure in the code is 11.5 by 5.5 inches - the Diagnostics screen showed the max to be like 116 (somethings).  Yes, I copied my old xml file into Mach before running the code.  Yes, my native limits were in inches.   I had the same problem with another code.
Bob @ BobsShop
