Hello Guest it is November 01, 2026, 02:21:07 PM
Author Topic: Jogging doesn't show tool tip in Turn!?  (Read 12426 times)
« on: October 20, 2008, 08:26:49 PM »
Hey guys, not sure if I'm doing something wrong, but I can't see the tool tip in Turn.  When I run a program I get a nice green line showing the tip location, but while manually jogging I get no verification on the screen.  Is there a setting I need to change for this?  BTW I'm using a smoothstepper with the Mach3 dev version R3.041.  Anywho, other than that I'm blazing parts out left and right, woohoo :)
Re: Jogging doesn't show tool tip in Turn!?
« Reply #1 on: October 21, 2008, 02:24:39 AM »
Afraid thats just the wy it is :(
« Reply #2 on: October 21, 2008, 01:44:49 PM »
That's not good at all :(  In Mill I usually jog around to reference points on the part for a sanity check before hitting the big green button.  In turn I can't even tell if I'm in the same block other than trusting my zeros are correct.  Maybe I'm just anal, but this seems like a pretty problem in usability.
